Old 06-22-2019, 03:52 PM
zmatt zmatt is offline
Question RV-6 canopy jettison handle on the ground
I am doing some avionics work and the canopy jettison handle is blocking removing one of the radios. Can I pull it and easily reset the handle? And if so does it require two people to steady the canopy? Thanks!
Old 06-22-2019, 08:21 PM
Jpm757 Jpm757 is offline
I would routinely remove my canopy using the jettison handle. 2 person job to be safe, 1 inside the cockpit and another to pass to someone outside. Installation is the reverse, be careful to get hinge pins aligned properly and not scratch upper deck.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 300+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. KOXC Oxford, CT
1941 J3 Cub skis,floats.
2019 dues gladly paid.
Old 06-23-2019, 10:12 AM
Snowflake's Avatar
I've removed mine twice using the handle. Both times it went back into place just as easily as when it was removed. I expected to have to jiggle it around a bit to get it to align, but it "just worked". I second the suggestion of having two people on hand for the job. Ideally three, one on either side to help guide it on and off, and then carry it back over the aft fuselage so you can get out of the cockpit and help one of them carry it away from the airplane.
Rob Prior
Old 06-23-2019, 10:30 AM
wirejock's Avatar
wirejock wirejock is offline
Default Jettison handle
For my education, what is a jettison handle other than the obvious.
No mention of it in my 7 plans.
I have heard of release pins in the two slider rollers.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/03/2019, plus a little extra.
Disclaimer
Old 06-24-2019, 08:41 AM
Snowflake's Avatar
Its the handle that goes on the instrument panel that when pulled will release the two forward hinge pins on the tip-up canopy. It's definitely in your plans.
Rob Prior
Old 06-24-2019, 10:01 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Unless you have a sliding canopy. Only for tip up. Yes obvious but may have some new folks.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 06-24-2019, 10:14 AM
dreed dreed is offline
This if from Vans factory 14, but you'll get the idea (candy striped handle in the middle upper panel). Stole the photo from a Rob Hickman post on here.
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
Working on finish kit/cowl
2018 and 2019 VAF dues paid
Old 06-24-2019, 02:36 PM
N661DJ N661DJ is offline
I recently had the opportunity to view an award winning RV7, tip up, that had No
canopy jettison handle installed.
As I see it, unless you are wearing a parachute and need to leave the plane while in flight, what good is the handle? I don't own or ever wear a parachute.
In order to remove the canopy, the mechanism can be easily actuated from behind the panel when the canopy is in the open position. Am I missing something???
I am presently finishing up a Tip Up build, and do not plan to install the release handle. That frees up some valuable panel Realestate.
Dick
Old 06-24-2019, 10:16 PM
rswalden's Avatar
rswalden rswalden is offline
Dick
Think of it as not a "Canopy Jettison" but a "Canopy Release" handle. Just another way to get out of the airplane during a ground egress if your tri-gear flips on its back during an off-field landing.
Bob Walden (Waldo), CFII-ASMEL
KFFC "Falcon RV Squadron" Peachtree City, GA
RV-7A Tip-Up, IO-390, 600+ Hours
RV-12 (Sold)... RV-12 Transition Training
EAA/AOPA/Vans Air Force 2020 Supporter
Old 06-25-2019, 08:21 AM
Snowflake's Avatar
Unless you're having an emergency, what good is any safety equipment?
The 7 plans set shows both canopy configurations. Or used to.
Rob Prior
