Go Back   VAF Forums > RV Firewall Forward Section > Traditional Aircraft Engines
Old 08-26-2018, 03:31 PM
Walt's Avatar
Walt Walt is online now
Default Which oil cooler for RV7A, 370 high comp, squirters?
New engine, new cooler, Texas heat, which would/did you choose?
AERO CLASSIC OIL COOLER HE 8001649 , 11 row
Part #: 08-07432
Mfr Part #: 8001649
$679
2006X AIRFLOW OIL COOLER EXPMT , 13 row
Part #: 08-06154
Mfr Part #: 2006X
$562.00/ea
10611R MEGGITT TROY OIL COOLER , 11 row
Part #: 10611R
Mfr Part #: 10611R
$917.00/ea
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-26-2018, 03:55 PM
Aggie78 Aggie78 is offline
Walt,
I don't know the answer for your specific question, but when I flew with Alex De Dominicis a few years back, I'm pretty sure his RV-7 was equipped with two separate 9-row oil coolers.
He wanted to make sure things stayed cool enough with all the low altitude work in that aforementioned Texas heat as well as dealing with the extra load/heat an air conditioning-equipped RV engine would be doing.
Two coolers may not be an option for you (hence your question) but I will say Alex's system seemed to work extremely well...
Rob
Rob Schroer
RV-7/N75WV
YIO-360-M1B
T67-Hicks Airport, Texas
VAF Monthly Donor
Old 08-26-2018, 05:31 PM
gfb gfb is offline
I'm guessing this is the Titan 370. Check with them on their recommendation. My 340 does not have the squirters and does fine with the stock 9-row but I understand the squirters move a LOT of the piston heat to the oil so need much more cooling.
As I said, call Titan, they will know what's worked best in the past.
RV-9A - started 01/2015, completed 07/19/2018
Old 08-26-2018, 06:36 PM
Hey Walt---the 2006X is the cooler use on the RV14---with a IO390. I havent heard of temp issues on the 14s. Might be a good choice.
Tom
Ridgeland, SC
Old 08-26-2018, 09:03 PM
elev666 elev666 is offline
Default Try Chief Aircraft
Iím working with the same engine here Walt,I know you have lots of extreamly hot days down there and canít comment on what work best , Iíve decided Iím going to try the 20006 13 row from chief aircraft supply , there web price was $349 last week, I must say my low Canadian $ has made me a bit of a thrifty shopper !
C-GARV RV 6
1946 C85 J3
RV 7 A project IO-360 -200
Garry Shepherd ,Grounds keeper @ CKS9
Dues paid 01/19
Old 08-27-2018, 09:02 AM
airguy's Avatar
airguy airguy is offline
Baffle or firewall mount?
I'm running the Aero-Classic 11-row on my firewall, parallel-valve IO360 with squirters. It's adequate, but only just, at lower altitudes. Above about 8000' cruise it's perfect.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2020 dues paid
N16GN flying 560 hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 08-29-2018, 08:39 PM
Walt's Avatar
Which aero classic PN are you running? They make the standard and the HE models. This will be a firewall mount.
Old 08-30-2018, 10:01 AM
airguy's Avatar
Sorry Walt - my memory proved faulty - it's the 10 row model 8000081 AeroClassic (standard, not HE) that I'm using, on the firewall.
On an extended max performance climb in full summertime afternoon heat, I'll see oil temps as high as 225 but they'll drop to 180-190 as soon as I level out in cruise.
Old 08-30-2018, 11:01 AM
TX7A TX7A is offline
Default Oil Cooler
Hi Walt
Here in Abilene, I was running high temps on my O-360 with oil squirters and a firewall mounted SW8406R cooler. (220-230F) I have a 4" SCAT above #4 to a fiberglass plenum that I made and is a reasonably smooth transition. (You may remember me calling you looking for ideas to get the temps down.)
I eventually decided to get a SW10611R after deciphering as much as I could from the forum. I called Pacific Oil Cooler to get some pricing info. I told the guy at Pacific what I had going on with my current setup. He thought that I would be very happy with their 'equivalent' HE cooler. It was also considerably less expensive than a pure-bred Stewart Warner. I got it and fabricated a bigger plenum to fit and installed it.
I have been very happy with it. My temps on a hot day (90-95+F) run around 190-195ish on a climb. It will top 200-210 if I push it. But I'm now usually more concerned about CHTs than oil temp. After level-off ~75F OAT, it'll settle in around 185 or so.
I haven't been out in any "really cold" air yet to see if oil temp is too cool. Slim chance of that in Texas.
Pacific's P/N is 8001649. I'm sending a couple of pics to your email.
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 08-30-2018, 12:26 PM
Roy Thoma's Avatar
Roy Thoma Roy Thoma is offline
Default Standard RF-10 parts
Walt,
I used the standard RV-10 oil cooler and firewall mount. 4" scat tube from the back of #4 cylinder suppling the air for the oil cooler. My oil temp is generally too low and I have restricted the amount of air to the cooler with 200mph tape.
My engine is a Lycon built parallel valve IO-360, 10:1 pistons, piston squirters, roller cam, flowed heads.
Regards,
Roy
N174RT (RV-7A) first flight 5/31/11, 1685hrs as of January 2020:
Tip-up, Lycon IO-360 EXP, WW 74HRT, AFS 5600T, AF-Pilot, IFD440, SL-30, echoUAT, D100 for backup, CQ1 headsets
Our other riveted aluminum monocoque RV is a 25í Airstream
Past aluminum monocoque vehicles:
N601RT (CH601HDS) First flight 5/03, 1550hrs after flying 8 years: 912ULS, GNS430W, SL-30, D10A Sold
1995 Midnight Pearl NSX w/BBSC Sold
EAA Chapter 105 board member 2010->2015
