Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 05-28-2018, 08:42 PM
Sleepy's Avatar
Sleepy Sleepy is offline
Default Strange discoloration on flywheel after prop removal
I removed my prop the other day to take it up to Northwest Propeller for some edge work. After I got back to the hangar, I decided to take off the flywheel and change the alternator belt. To my surprise, I discovered the two mating surfaces between the flywheel and the crank where stained (see below). The mating surfaces on the other side between the flywheel and prop are clean.
This is off an RV-4 (1992) with about 850 hours on the engine and 300 SOH (2008) on the prop.
While the stains look oily they are not. There is very little build up and they are dry. Any ideas about what is going on?
Scott
Scott Price
aka "Sleepy"
RV-4 - N485AB Flying
RV-8 - N687SD Fuselage 1/2 Done
Old 05-29-2018, 06:51 AM
Super Moderator
Default Bolt torque?
Have the prop bolts been torqued properly with every seasonal change? It looks like they have been loose at one time or even for some time. A wood prop that is not properly and regularly torqued can even catch fire from the friction of movement on the flange.
Vic
Vic Syracuse
Kitplanes "Checkpoints" monthly column
www.Baselegaviation.com
Old 05-29-2018, 08:28 AM
Kyle Boatright Kyle Boatright is online now
Vic
Didn't the poster indicate the discoloration was between the crank and flywheel? (Not the prop and flywheel.)
Maybe there is a loose fit between the crank lugs and flywheel? In any case, it does look like a heat related event with slippage between the two surfaces. I'd check the fit and also take a close look at the prop and the bolts.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 05-29-2018, 08:41 AM
Sam Buchanan's Avatar
been here awhile
Are those oil stains on the inner bore of the flywheel? Maybe the crank seal leaked at some point in the past? Not sure how that would happen but the flywheel looks oily....
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 05-29-2018, 09:03 AM
Jpm757 Jpm757 is online now
I agree with the above. Somethings moving!
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 300+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. KOXC Oxford, CT
1941 J3 Cub skis,floats.
2019 dues gladly paid.
Old 05-29-2018, 09:16 AM
az_gila's Avatar
az_gila az_gila is offline
Question Paint
Could someone have painted the back of the flywheel where it was not meant to be painted?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-29-2018, 02:39 PM
Snowflake's Avatar
Maybe a wooden spacer?
Seriously though, I agree with the others that something has been moving.
Rob Prior
Old 05-29-2018, 08:41 PM
molson309 molson309 is offline
In your first picture it looks like the wood prop has radial stains on it in the area of the lightening holes. Sure looks to me like some liquid/grease spun out from the hub area.
Mark Olson
RV-7A First flight 2005 Sold 2019
F1-EVO Rocket First flight 2010
Old 05-29-2018, 09:06 PM
JonJay's Avatar
JonJay JonJay is offline
Arrow
It looks like oil contamination to me but hard to tell.
Clean flange and flywheel, check for pitting, marring, scuffing etc... If something is moving, there should be wear marks.
Check tolerances of bolt holes for flange, flywheel, and prop, have bolts inspected (any prop shop can do this), install reworked prop, then set up an inspection interval. I would inspect at 5 hours, 15 hours, and 50 hours. Those are pretty arbitrary numbers that i would discuss with my AP friends and other resources
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-30-2018, 07:18 AM
DanH's Avatar
DanH DanH is offline
Wood prop or metal? And what is the streaked material and black material visible through the holes in the first photo? The streaked material seems to be completely filling the big lightening holes
Dan Horton
RV-8 SS
Barrett IO-390
