Old 07-14-2019, 11:46 AM
bob888 bob888 is offline
Default VP-X Disconnect Problem
I have a Vertical Power unit with a G3X system. Recently there have been random disconnects of the AHRS unit. I can reset it on screen using the VP-X page and then OK for the rest of the flight. Anyone else experienced this? Fix?
Old 07-14-2019, 12:20 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello Bob,
You will want to make sure that Current Fault Detection is not enabled on the VP-X for this unit.
The VP-X manual warns that this feature should not be enabled for low current avionics devices like the GSU 25.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 07-14-2019, 12:29 PM
rongawer rongawer is online now
I have experienced this issue, however it reset on its own within seconds. I do have active logging on one second increment and looking at my logs, I donít see any interruptions with the VP-X, voltage or over current faults. What makes you suspect the VP unit? It seems more likely to me that there is an issue with the ADHRS (I have a GSU 25).
I had not experienced this until I updated the G3X to v8.3. Itís happened twice since then, but I have no idea whatís causing it or how to repeat it.
This topic probably belongs in the avionics forum...
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 07-15-2019, 07:28 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I saw this same issue over the weekend. Message says AHARS 1 disconnect, or something like that. Traffic unavailable warning and then it rectified itself within 10 seconds or so. I am going to check the logs today and see what's up. Never seen this message before. Also saw the system act as though the MFD was failed and the engine instruments appeared on the PFD for a few seconds, then disappeared. This has happened twice now since the software update. This is a non-touch system.
Bill Peyton
RV-10 - 995 hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 07-16-2019, 09:33 AM
Originally Posted by g3xpert View Post
Hello Bob,
Steve
I don't Current Fault Detection enabled for this device.
Due to the fact I have the VP-X Sport with fewer power circuits than the Pro version, I have my GSU 25 fused to the same power circuit as my GEA 24. I've not had any interruptions with my engine indications, so the issue is not with the VP-X, but rather it's the ADAHRS or related component.
Ron Gawer
Old 07-16-2019, 09:59 AM
Brantel's Avatar
Brantel Brantel is offline
I know these issues can end up being very specific on what components are installed and the critical specific details but as one data point:
I have a dual screen G3X Touch System.
PFD - Uses a GSU73 as its primary AHRS
MFD/PFD - Uses a GSU25 as its primary AHRS
VPX-Pro
I have not experienced any drop outs of the GSU25 that I have noticed with ver 8.30 firmware. Possible I have missed em though if they are fast.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
