Old 08-07-2015, 10:07 AM
DHeal DHeal is offline
Citabria available at KSTS - try calling Sonoma Jet Center or North Coast Aviation??
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 870+ hours (as of Jan 2020)!
VAF donation through June 2020.
Old 08-10-2015, 01:27 AM
tectweaker tectweaker is offline
Mike is definitely the way to go.
I would highly recommend him instead of the closer options. He taught me a lot more than in a day than I learnt in 10 with other instructors. Worth the travel cost in my opinion.
Old 03-20-2019, 09:45 PM
boyerwood boyerwood is offline
Look everyone... What was the last airliner with a tail wheel...last bomber, fighter...or even general aviation aircraft built with a tail wheel. They quit building them and used a nose gear configuation for a reason. I mean the whole aviation industry world wide did.
So, I realize there is a challenge argument or a slight speed argument...but the entire aviation industry world wide has made the decision what is the best configuation. I assure you Boeing is not stewing over whether the 797 will be a tailwheel configuration.
Old 03-20-2019, 09:59 PM
wjb's Avatar
wjb wjb is offline
Originally Posted by krwalsh View Post
San Carlos Flight Center at SQL has three taildraggers:
A Super Decathlon
A Citabria Explorer
A Cessna 140
I did my tailwheel endorsement in the Super D. It was really, really fun. Near the end of my training I would take off, do a continuous turn from departure to downwind to keep it tight, pull to idle opposite the touchdown point, slip in in hard to touchdown and wheel land it before firewalling the throttle and doing it again. At one point I was logging a landing in less than 0.1 on the Hobbs. So much fun.
San Carlos Flight center no longer has a tailwheel program, unfortunately. The Super D and Explorer are no longer on the line and their main TW instructor moved away. I was a long time member and flier until this all came down last September.
West Vally Flying club and Advantage Aviation at KPAO have a good tailwheel fleet and good instructors.
Bill Bencze
N430WB RV-7 #74152, tip-up; IO-360; CS. Pushing toward first flight in 2020!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2020 donation happily made
Old 03-21-2019, 09:27 AM
506DC 506DC is offline
Tailwheel experience will just simply make you a better pilot. I have given tailwheel instruction for years and have been told by many tri-gear pilots that it has helped their tri-gear flying skills and specifically landing and x-wind skills. One of the main reasons that nose wheel pilots damage their airplanes on landings is because they don't always land on the main gear. They also don't keep the weight off the nose wheel during the touchdown and roll out phase of landing. I have been also told that their tail wheel instruction have helped them maintain a consistent approach speed. The proper approach speed is much more critical in tailwheel type aircraft. If you land a noise wheel airplane as you would land a tailwheel airplane you are much less likely to damage your noise wheel and with better directional control skills less likely to lose control on landing.
Old 03-21-2019, 10:05 AM
dnh98221 dnh98221 is offline
Cuz I want to...
RV-3B
PA-18
C180
Old 03-21-2019, 04:14 PM
merlin3 merlin3 is offline
We probably shouldn't be flying propeller driven aircraft either since the airlines aren't using those...
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 03-21-2019, 07:51 PM
akschu's Avatar
akschu akschu is offline
How narrow minded! Nose draggers are great if you want to go from pavement to pavement, but once you get past that and start exploring, you quickly find that extra prop clearance and gear strength open up all kinds of options in the backcountry.
A cub would really suck with with a nosewheel, and if you think low and slow isn't part of GA, then you are seriously missing out.
Anyway, onto the OP's question:
NOT ALL TW INSTRUCTORS CREATED EQUAL. (sorry, not meaning to be rude, but it's important)
I got instruction from two different people, and I learned more in 2 hours from the second guy then I did the entire time I flew with the first.
Also, tailwheel isn't hard, but it does require you to fly the airplane well, not poorly then stop flying the second you hear the thud.
I was taught like this:
Use the rudder to keep the airplane completely parallel with the runway. Whatever happens, pitch up, down, whatever, do whatever you have to do to keep it parallel.
Use the aileron to keep the airplane in the center of the runway. If you drift, use the aileron, while keeping it parallel with the rudder.
Use the elevator to set the pitch, and the throttle for altitude until you get good at understanding what you need for tail high, low, or 3 point then mix/match.
So if you want a wheel landing (better for crosswinds) you are doing to use less elevator and a flatter pitch, but more throttle so you don't sink too fast.
If you have a serious cross wind, well, you will find that keeping the airplane straight with the rudder, and into the wind with the aileron will give you a one wheel then other wheel landing, just like you want.
It's not rocket science, but it does take some skill, and it's very rewarding.
Old 03-21-2019, 08:01 PM
akschu's Avatar
Look boyerwood, when was the last airliner that landed on a grass runway.
You can buy a lot of new or kit general aviation aircraft with a tailwheel:
http://mauleairinc.com/
http://cubcrafters.com/
https://justaircraft.com/
https://www.rans.com/
http://www.americanchampionaircraft.com/
http://www.burlac.com/aero_sedan.html
https://aviataircraft.com/husky-aircraft/
http://www.kitfoxaircraft.com/
https://bearhawkaircraft.com/
AND
https://www.vansaircraft.com/
Old 03-22-2019, 12:12 PM
akschu's Avatar
Always exceptions to the rule, but cool to sea heavies on grass....
