  #291
Old 05-04-2018, 06:37 AM
Super Moderator
Default Try this one
I've been using the ALFI from Aircraft SPruce for a number of years now. It's a little pricey, but with the random flashing pattern it is really amazing. I had a tower chief come and tell me that whatever I paid for the lights it was worth it, as they see me before anyone else, including the big jets.
https://www.aircraftspruce.com/catal...clickkey=52910
Vic
Vic Syracuse
Kitplanes "Checkpoints" monthly column
www.Baselegaviation.com
Old 05-04-2018, 07:29 PM
Bill Boyd's Avatar
Default prelim report:
The Perihelion module works fine to wig-wag a pair of landing lights - each made from a trio of "3 x Cree XM-L2 U3 Neutral White 4500K 3800 Lumens 8.4V 1-Mode LED Drop in for TrustFire 3T6 Flashlight (Dia 51mm)" flashlight heads, fed 10.3V via a DC-DC bucking voltage converter.
It's impressive.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 02-19-2019, 05:30 PM
rocketbob's Avatar
rocketbob rocketbob is offline
I recently had the challenge of retrofitting lights in a RV-4 without hurting the paint. Here's what I came up with. Used one Duckworks lens cut in half for both wings. Brackets allow adjustment as the light bracket has 3/8" holes secured by flat clamping plates. I put them as far forward as practical to reduce aperture effect. Total cost ~$50 using kaidomain LEDs.
Please don't PM me! Email only!
Bob Japundza CFI A&PIA
N673AC RV-7 borrowed horse
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 02-20-2019, 05:50 AM
Super Moderator
Well done! Looks very nice.
Vic
Vic Syracuse
Old 02-20-2019, 06:32 AM
Bill Boyd's Avatar
Default I was just thinking about this thread
since, looking for something to do to keep me moving forward while I wait for engine pieces to return from the overhaul facility, I cycled back around to some unfinished business on the leading edge...
I decided the little buck supply was a little under-muscled for the current demand of six flashlight heads all on at one time, so I decide to order a second unit, install each supply in the wing bay mounted to the aft side of the landing light bracket, and wig-wag them from a Perihelion module located in the cabin. You can see the three-head light on top of the wing, awaiting installation once I get the proper 10-32 screws.
I'm impatient to see the wig-wag in action somewhere besides on the test bench!
Bill Boyd
Old 02-20-2019, 07:29 AM
Timberwolf Timberwolf is offline
I’m running 4x the Amazon par 36 leds and attempted using a flasher from CRAZEDpilot.com. However, it didn’t have what it takes to control these lights. CRAZEDpilot says they aren’t fast switching led drivers causing th issue, but to me it looks like it just doesn’t have the power that they claim.
I’m interested in the perihelion but wish it was just a 3 way switch to not have to put in another hole, or that it was a 3 way switch to give wig wag/off/constant. O well, gotta give up something. I’ll get one of these ordered.
Side note, does backfeeding the switch hurt anything? If I turn on the landing lights without turning off wig wags will it kill the circuitry?
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P flying
Aero Engineer, A&P
Old 02-20-2019, 07:34 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
For my dual BajaDesign S2 Pro installation I wired in an inexpensive Bussmmann 232 electronic flasher which is rated at 20A and works great. Instead of two switches you can use a single 3 way switch and get the same results. Backfeeding has not been a problem.
With this configuration, if both modes are selected the constant ON "landing mode" has priority and over-rides the flashing "recognition mode". This would not be an issue if you use a 3 way switch. Here is a link to a YouTube video of the lights installed on my non RV in both the landing and recognition modes using the above circuit. Just another way to "skin a cat".
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2019 Dues Paid
www.PuertoRicoFlyer.com
Old 02-20-2019, 11:59 AM
Ted RV8 Ted RV8 is offline
Has anybody used the Baja Designs Squadron Sport lights yet?
Price is $129.95 and puts out 3150 Lumens. https://www.bajadesigns.com/products...t-led-spot.asp
Considering these or the Squadron Pro more light and doable the price
Also looking at the FlyLED wing leading edge kit. Middle of the road price compared to the Baja Designs. 4900 Lumens.
https://flyleds.com/products/#!/Comb...ht/p/109859298
Like the idea of one aimed down which suits a taidragger very well. Not sure if these work with Perhillion wig wag switch which I’m already running.
Old 02-20-2019, 03:20 PM
Bill Boyd's Avatar
One question I was able to answer for myself is that the Perihelion module does not require ballast resistors to function with LED lights as some others do. At least the Kaidomain Cree flashlight heads I used integrate with the wig-wag without any bootstrap parts added.
Bill Boyd
Old 02-28-2019, 09:14 PM
gator88 gator88 is offline
Default Perihelion wig wag
Has anyone installed the Perihelion wig wag and wired it like in drawing C on the Perihelion website?
http://www.periheliondesign.com/wigwagmnl.htm
The diodes suggested are circuit board diodes that need to be soldered - does anyone know if there is a similar diode available with screw terminals or spade terminals? Would this diode need to be mounted with a heat sink and thermal pad?
