Old 06-30-2019, 03:38 PM
dsm8 dsm8 is offline
Default RV-12 Instrument Panel
Hello RV-12er's
As much as I love building, I like flying more. Does anyone know of an organization/company that is willing to build and wire the avionics supplied with the kit by Vans and send it to you so one can "plug and play" Any opinions would be greatly appreciated.
Thank you
Don "Donnie Mac" MacMillan
RV-12 12808
Finish kit 80% done 80% to go
donald.macmillan@ynhh.org
Old 06-30-2019, 03:48 PM
bcondrey bcondrey is offline
SteinAir. FWIW, they also build the wiring harnesses supplied by Vanís.
Bob
RV-10 builder x2
RV-7A under construction
EAA Tech Counselor
Old 06-30-2019, 04:29 PM
skydiverlv skydiverlv is offline
12 is essentially plug and play. I think even a novice could have the avionics up and running in 8 hours. Also I would think it easier to have panel installed and then do the avionics. RV12 is quite different than most builds. I see no gain, and possible lost time deviating from build instructions.
Larry Vandegrift
ULPower 260is
Old 06-30-2019, 08:32 PM
John-G John-G is offline
Don-
Could not agree any more with Larry ... wiring the the RV-12 instrument panel is, for the most part, a snap in that virtually everything is connectorized. It is NOT a daunting task ... just carefully follow the KIS one step at a time and you will have the entire panel wired in short order, plus you will also have a fundamental understanding of the layout for the wiring.
Happy building,
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2020
Old 06-30-2019, 09:07 PM
An added bonus of doing the install yourself is that you will gain the confidence and understanding of your plane that will let you do your maintenance, inspections and modifications after getting it licensed.
