Hi all,
I am hot and heavy into the wiring phase. I need to plan out the switches on my right console. I have the following switches to deal with(am I missing anything?) Contactor, alternator, ignition are on the panel. Trim, flaps, boost, starter are on the stick.
Panel dimmer
Instrument dimmer
Nav lights
Strobe lights
Landing Light
Taxi Light
Wig Wag
Dome Light
Pitot Heat
Questions:
How far back from the front bulkhead did everyone start? How far forward of the rear bulkhead?
Switch spacing: I think One inch on center works okay. Is that too close?
I was thinking to arrange them so that those I would use at night would be easiest to get to: landing, taxi, wigwag. Nav and strobe get started on the ground, so less of an issue for ease of location.
Do you find yourself hitting the switches inadvertantly during flight? Should I use switch guards?
It looks like orienting the switches to work left and right is more sensible that forward and aft. Since some of these will be on more than off, I was thinking on to outboard. Thoughts?
Anyone have any good pictures of their right side console?
Michael Wynn
RV 8 Wiring
San Ramon, CA
Panel dimmer
Instrument dimmer
Nav lights
Strobe lights
Landing Light
Taxi Light
Wig Wag
Dome Light
Pitot Heat
Questions:
Michael Wynn
RV 8 Wiring
San Ramon, CA
