I have had good luck with factory gaskets-----be sure things are clean when you put it together.
Also, check for nicks or other surface defects on the sealing surfaces.
Once I thought I had a leaking mag gasket, but it turned out to be a small square cover just below the mag-----you might check any nearby leak sources.
