Old 06-22-2018, 07:46 PM
jbario jbario is offline
Default Fuel draining to inspect fuel strainer
Inspecting/cleaning the fuel strainer is in the conditional inspection checklist. Looking at pg 13-8 of the RV-12 maint. manual, one is supposed to drain the fuel in the aircraft before accessing the fuel strainer. Has anyone come up with a way to avoid draining the fuel during the process of accessing the fuel strainer? This was my first conditional inspection since I purchased a 2 yr old ELSA from another fellow.
Old 06-22-2018, 07:59 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
There are two strainers to check..1. The gasolator-no need to drain fuel tank...simple close in cockpit fuel valve. You will get a little spillage, but not much..; 2. the second, the in tank strainer (out-flow fitting @ bottom of fuel tank). Checking that one requires an empty fuel tank.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 06-22-2018, 09:56 PM
I have had success inspecting the tank finger strainer with a borescope if the fuel lev l is less than 5 gallons.
Old 06-23-2018, 08:39 AM
Phantom30's Avatar
Actually Rich, I run a flow test after I remove the gasolator bowl/screen. If you get full flow as per you initial flow test; i’m Good to go.
Are you speaking of a led to computer type?
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
Old 06-23-2018, 12:44 PM
I run the engine to about 4 gallons indicated and then snake a a video borescope down the filler neck. I like it because I can see if there is any foreign material in the tank.
Old 06-23-2018, 05:55 PM
How do you guide the scope and lift it over the baffles to see the finger screen?
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 06-24-2018, 05:31 AM
TomVal's Avatar
TomVal TomVal is offline
This is one inspection I don't totally agree with. There was no annual requirement to do the same with my RV-8, and I assume the same applies to the other RV models. The fuel strainer screen in the RV-12 is coarse. It would take one heck of a contaminant to block the screen. Plus I don't like messing with loosening and tightening the fittings on soft aluminum fuel lines. Lastly, I care not to deal with the potential risks associated with transferring fuel, and I am not a fan of sticking anything electrical into a fuel tank.
I do exercise extreme care when filling the tank to include holding a clean rag over the filler neck while fueling. During the condition inspection after inspecting the gascolator screen I disconnect the fuel line at the mechanical fuel pump and conduct a flow test.
From an operational standpoint, get familiar with your fuel flow during takeoff, climb, and cruise. Any pressure fluctuations may also be indicative of contaminants in the fuel thus warranting further inspection.
During my six years of ownership of the -12, I have inspected the main tank screen twice to check for contaminants and found none. Of course if contaminants were found at the gascolator that would be cause to inspect the main screen.
Regards,
Tom
P.S. I assume you have the split aft baggage compartment bulkhead panel. If not, you will have to pull the tank anyway for the condition inspection to check the security of the the right flaperon attachment fittings under the floor boards.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 06-24-2018, 01:04 PM
Depend on your interpretation of FAR 43, appendix D I guess, but other than that you are correct, because unlike the RV12, none of the other models have a factory published inspection checklist. It was required for S-LSA, and is required to be supplied to E-LSA builders.
A major reason for inspecting the tank finger screen (besides that it can be) is that the RV-12 is much more likely to be self fuel from jugs with a much higher probability of inducing undesirables.
Scott McDaniels
Hubbard, Oregon
