Torque values are for the bolt in most cases, not really associated with what it's holding in place. Therefore the normal torque for an AN3 bolt of 20-25 inch lbs. should apply. Now, if your going into a plate nut, you may find it takes that much torque to make it turn, in those cases I had to use old fashion judgement in snugging it up. It doesn't take much to torque an AN3 bolt into two pieces.
