Old 07-17-2018, 07:54 AM
flyabq flyabq is offline
Question Getting ready to start RV-7 Slow build wings. Need input
Hello,
I am getting ready to start some slow build 7 wings. The input that I am looking for is what do you wish you had done when you were building the wings. i.e. I wish I had added this lightning hole for future wiring, or I wish I had run the wiring for the landing lights before I closed up the wing. etc. I look forward to your input and can't wait to get this beauty finished and flying.
Old 07-17-2018, 08:16 AM
Default 7&8.
As the 7 and 8 wings are now the same. I wish I would have put our electrical conduit a little further aft of the main spare. We put it about an inch behind the spare and that was good when we started the build, but when we got to the point of installing the A.P. servos it was a little close to the roll servo leaver arm. I would have moved the conduit to the rear another inch if I had know.
Other than that you have a very good wing to build and fly, get going.
Yours, R.E.A. III # 80888
Old 07-17-2018, 08:48 AM
airguy's Avatar
airguy airguy is offline
Run your electrical conduit all the way to the wingtip, install a couple spare wires for future use, or leave a length of string or twine for a pull-string to drag more wire in for possible future use.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 360hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 07-17-2018, 09:15 AM
wirejock's Avatar
wirejock wirejock is offline
Default 7 wing
I wish I had run the plumbing near the conduit location. That would keep it away from the AP servo and make an eeasier entrance to the fuse to the ADAHRS located aft. I doubt very many out the ADAHRS up front like old school instruments anymore.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 07-17-2018, 11:28 AM
jibby212 jibby212 is offline
I second Wirejock, I ended up routing my AOA and Pitot plumbing just behind the electrical conduit. This worked out much better exiting the pitot mast, clearing the bellcrank, and cleanly entering the fuselage.
Old 07-17-2018, 11:49 AM
jcarne's Avatar
jcarne jcarne is offline
Well darn it, now I wish I had done this too, makes way more sense.
1. I wished I had installed the needed bushing where my wire for the left fuel sender passes through the spar BEFORE putting the fuel tank on. That way you can enlarge the hole ever so slightly and get the proper bushing. This is not needed if you don't install a flop tube.
2. I also wished I had hired out the rib deburring.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 07-17-2018, 12:08 PM
Ralph Inkster Ralph Inkster is offline
Lots said about conduit runs, I can only add to say make them BIG conduit, like 5/8” or so. Location I like is between the first & second lightning hole just below the top skin.
Nearly forgot, angle the conduit run down as you get to the inboard rib as you want the wires to penetrate thru the fuselage below the seat floor pan.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
Old 07-17-2018, 12:15 PM
Default Welcome to VAF
Jeremy, welcome aboard the good ship VAF
Think about all the things that get installed in a wing-----then plan for a few new ones that could be developed before you get done.
A/P servo.
Leading edge landing lights.
AOA.
Heated pitot.
Wingtip antennas.
Wingtip mounted magnetometer.
Wingtip mounted extra fuel.
Old 07-17-2018, 01:12 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
A few photographs on this thread would be worth "a thousand words" to those of us who are working on the wings.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
N79599/APRS Automatic Position Reporting System
“Certainly, travel is more than the seeing of sights;
it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
"It should be added that the sublime beauty of the facture brings within the realm of discourse the substructure of critical thinking. " -using Doug's Art Critique jargon link and my birthday, I get this!
Old 07-17-2018, 07:24 PM
Maxrate Maxrate is offline
If your installing heated pitot, be sure and leave a “service loop”. This was some good advice given by an AP friend. It would stink if you had to de skin part of the wing to service the heater element or pitot mast.
Mark Malone, RV7
Wings complete, SB 14 complied with, fuselage in progress.
N442MM reserved
http://www.mykitlog.com/MikeMike
2018 Donation gladly paid.
