Christer
I received new bolts, nuts and washers from Genuine Aircraft Hardware for my RV-8 landing gear. I had spoken with Tom Brink and he suggested using the MS21250-06028 bolts (200ksi), MS21299C6 chamfered washer and MS21299-6 washers both hardened (260ksi) and a DHE-45079-6NM nut rated at 220 ksi. All are 12 point so access in the gear tower was much easier, which was one of the driving forces behind the change. I was very pleased with the installation and the ease which it all went together. This setup is significantly stronger that the stock Van's recommended bolt and nut combination. The nut also has an elastic lock feature (can't recall the name). Each installation is slightly different with regard to bolt length, but mine worked with the one listed above. The nut is fully engaged, but only a thread showing.
