Old 08-18-2018, 08:31 PM
mikesmithstormlake mikesmithstormlake is offline
Default Crush Ring on magnetic plug?
Cleaned My Mag plug today and found there to be no crush ring. Is there supposed to be one and if so what is the part number. Thanks in advance.
Old 08-18-2018, 08:39 PM
John-G John-G is offline
Mike ... don't remember there being a washer on the magnetic plug. A quick look at the illustrated parts catalog will verify that I'm pretty sure.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 08-18-2018, 08:55 PM
Does not show one. Just seems odd to me. thanks John
Old 08-18-2018, 11:37 PM
I use the same type as is on the tank drain plug on mine. The engine was delivered with a crush gasket. If yours doesnít leak without one I wouldnít worry about it.
Old 08-19-2018, 02:27 AM
Piper J3 Piper J3 is online now
No gasket (crush washer) used for the magnetic plug. Just be sure to safety wire...
Hinckley, Ohio (1OA2)
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 415
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 08-19-2018, 05:28 AM
todehnal todehnal is offline
Default Crush Washer
I just went through this same dilemma. While changing my oil last month I discovered that the magnetic plug on the gearbox did not include a crush washer. I was sure that I had forgotten it at the last oil change. I rooted through my parts and found a bag with one crush washers in it that was labeled "Magnetic Plug" and it fit, so I installed it. While at Oshkosh this year, I visited the Lockwood Aviation booth and asked for a supply of new ones. They searched their inventory, searched the parts diagrams and came up with nothing. Finally, they called and spoke with their Rotax technical department at Sebring and were assured that there is no crush washer intended for that plug. Long story to a short question, but the answer from the professionals is that:
"No Crush Washer Is Intended on The Magnetic Plug"
By the way, the oil tank drain plug crush washer is a pretty good fit, and I can't see any harm in adding it. ..............Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 08-19-2018, 02:16 PM
PilotBrent PilotBrent is offline
I never rely on my memory when working on the ROTAX. That's what the current illustrated parts manual is for. Keep all five of the PDF manuals on my iPad in hanger.
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 08-19-2018, 05:34 PM
Originally Posted by RFSchaller View Post
I use the same type as is on the tank drain plug on mine. The engine was delivered with a crush gasket. If yours doesn’t leak without one I wouldn’t worry about it.
The only crush gasket (AN900 style) that is used on the Rotax 912, and would have been installed when delivered new is the one on the oil tank drain plug.
The magnetic plug is a large flange plug and does not use any type of crush gasket or washer.
Scott McDaniels
Hubbard, Oregon
Old 08-19-2018, 08:38 PM
Scott, since itís been over six years since my engine was delivered Iíll take your word for it, but I would have sworn it had a gasket. Bottom line is if it doesnít leak with or without why sweat it?😜
Old 08-19-2018, 09:32 PM
if that is true Scott what is part number 950 141
