Spark Plug Gapping Tools - are these good ones?
Saville
Hi all,
I worked with a mechanic to find out why I was losing 200 rpm on mag checks. First check was the plugs and we found 2 bad Champions. I replaced those with Tempest. Mag drop now back to where it used to be - problem solved.
I'm going to replace the other plugs with Tempests. The A&P was very considerate when I asked him if it would be ok if I worked with him and learned how to remove, clean, gap and install the plugs.
So now I need the tools necessary to do this job. I already have a torque wrench (Cleaveland CDI), and I can borrow a mechanic's cleaning rig when I need it.
But I need the tools to remove, gap, install the plugs. I found the following gapping tools on Aircraft Spruce and I was wondering if there was any experience with these tools and how well they work:
http://www.aircraftspruce.com/catalog/topages/expansiontool12-03391.php
http://www.aircraftspruce.com/catalog/topages/precisegap.php
http://www.aircraftspruce.com/catalog/topages/ATSgap.php?recfer=16137
Will they do the job? Are there better versions out there? Any advice appreciated.
Thanks!
How does that "Electrode Erosion Gauge" work, please?
Way I understand it is this:
A new plug will have a center electrode that is circular in cross section.
As you use the plug that center electrode erodes to look more and more like a football. The sides facing the outer electrodes are the places where it erodes.
So to keep the gap the correct value you push the outer electrodes in towards the reducing center more and more.
When it gets to the point where the outer electrodes slip into the hole, in the erosion gauge, the center electrode has eroded too much and you toss the plug.
