I have a Garmin SL40 as my primary comm and a KY-97 as my backup. The Garmin performs great but has less transmitting power than the KY-97 so I'd like to get it operating properly.
The issue is that the KY-97 has constant "static" when NOT receiving or transmitting... almost like the squelch is not set correctly on that particular radio but both radios feed through a PS Engineering 6000 audio panel and the squelch is set correctly.
Does the KY-97 have its own squelch that can be adjusted independently of the audio panel?
Again, the radio receives and transmits perfectly but when in between communications its nothing but static with 4 quick clicks about once per second. Any ideas what the problem might be?
As a side... the wire harness was professionally built so I don't think that is the problem.
