Dynon Roll Servo in RV-14 wing
Kbolvin
Member
Has anyone put in the SV42 roll servo? Seems when the aileron is fully deflected down the servo arm hits the Molex connector installed right next to the servo. But I don't have the wing mounted on the fuse yet so I'm not sure if the aileron travel is limited by stick travel so that the servo arm can't go that far. But it doesn't take that much deflection of the aileron for this to happen.
Yep - installed in a flying RV-14. No problem.
Don't shy away from changing out the connector if needed. I replaced almost every Van's provided connector as I found them to be clunky, as well as the Van's provided wiring.
Great, thanks Carl. That's a load off my mind. I had a feeling there had to be some kind of mechanical limits and not using a Molex to limit travel. :)
