GTN Help
swordtail
I did an update that was posted for the GTN 650 keypad and update and now I'm stuck on the configuration page. The unit will not change screens back to normal operation. I can go through all the setup menses on the config page and the update screen but no home screen. I have a current subscription for updates. I'm new to the gtn and need a little help for the team.
Remove the firmware update SD card and reinstall the database card.
If you used the same card (bad idea) you will have to reformat it and reinstall the databases or delete the Garmin firmware update files off the card.
Yes. What Brantel says. I did the same a month ago. U just want data on the SD card for flying.
