O-320 cylinder spacing
sblack
Does anyone have a dimensioned drawing that shows the distance between the centers of the cylinders on an O-320? I am making a split plenum and that dimension would make it easier to fabri-cobble the inner baffle wall which will go against the lower cylinder barrel fins. I could just rough measure it, but knowing the real value will make it easier.
thanks guys. Probably good enough for my needs. I will make my parts out of a cornflakes box and adjust as required before killing good metal.
cheers
Scott
