the ones Vans sells. They are easy to install and they allow you to remove the ring assembly if you need to. They are also sturdy enough to tie up any loose ship you might come across!
I fabricated brackets from scrap aluminum a few years ago and ordered some straps/plastic buckle from Amazon. Added some plastic scrap to them as well so that the aluminum edge wouldn't wear on the strap.
