jcbarker
First my engine setup:
IO-360 Parallel Valve
Horizontal induction
dual Plasma III ignition
The problem:
Occasionally, my engine will run rough. I mean rough enough to shake the stick and make the horizontal stab visibly vibrate. All engine parameters look good and there is no perceptible loss of power. The first time it happened I started looking for a place to land. By the time I had figured out where to go and started heading there it started running smooth again. This happens almost every time I fly after a warm start. I've tried running the boost pump with no change. I'm mystified. I thought I'd post the question before I start poking around blindly.
Any thoughts?
JB
The problem:
Any thoughts?
JB
