Old 11-10-2018, 04:06 PM
birddog486 birddog486 is offline
Default 360M1B ?
I need a measurement of the thickness of the ring gear assy. where it bolts to the crankshaft flange. IOW: how thick is the flywheel?
Old 11-10-2018, 05:08 PM
flyvansrv7 flyvansrv7 is offline
Default measurement
Measured with micrometer mine is .249" or just under 1/4"
John
Bellevue NE RV7 builder
flyvansrv7@gmail.com
Old 11-11-2018, 07:37 AM
Thanks John
Old 11-11-2018, 10:39 AM
RV6_flyer's Avatar
I just measured a Superior Air Parts starter ring gear and came up with similar reading. 0.2516" using my micrometer. If I ran some scotch bright over mine, I expect that I would get a slightly smaller reading.
The part I measured was removed from an engine that was removed from a flying airplane yesterday and has had no cleaning. I was wiped with a RED rag and measured.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-11-2018, 12:40 PM
That's great thanks, I probably should have asked how thick the prop flange is on the crank itself also.
Old 11-11-2018, 03:30 PM
Default crank flange thickness
my crank flange thickness measured .439" on the YIO-360M1B.
John
Old 11-11-2018, 04:06 PM
RV6_flyer's Avatar
The Superior Air Parts crankshaft flange sitting in my hangar was just measured at: 0.4435" and that may include some dirt.
Lycoming has SB201F that has minimum thickness and allowable tolerance listed.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
