I've switched to the iS configuration and want to wire another landing light for the left wing. I already have the LL installed in the right wing, using Aerosun from Vans lighting kit. I'm getting ready to pull another wire to the right LL. I think it's called the sync wire for wig wag. Currently, the red, black, and yellow wires on the back of the LL are being used and the blue and green wires just have terminators on them. Looking at the Aerosun schematic, it seems the sync wire connects to the green wire in the right LL and the blue wire in the left LL.
I want to get the wire pulled, connected, and get the landing light on the right wing buttoned up. I don't think Vans has a specific add on kit, parts list, or instructions yet.
For those of you RV12ers that have dual LL, am I safe to pull one more wire, connecting to the green lead on the right wing? If I am correct, which position would the sync wire be in the blue plastic connection at the wing root as there are 2 open positions available? (Older 12's have a different connection at the wing root) Thanks
