Old 05-13-2017, 04:21 PM
Redbud40 Redbud40 is offline
Default IK Technology IK 2000 Engine Monitor
I have this unit installed on my panel. ( 2nd Owner) Trying to get a few more hours out of it till a possible panel upgrade. Does anyone have any working knowledge past or present of this unit. I need to change the basic settings i.e. RPM settings for pmag. Trying to access a main screen for settings etc. with no luck. Not much info on the web. It would be similar to access a start up menu or similar on initial installation for engine selection and other variables. Thanks for any help.
Mike
Mike Robinson
RV-6a N731CK
52F
Old 05-13-2017, 04:40 PM
bsacks05's Avatar
bsacks05 bsacks05 is offline
I installed one of those in 2006 during my build. It still works great but I don't think the settings are user accessible. Early on I had to have the fuel increments changed and had to send it back to IK to have the processor reprogrammed. I don't think they are in business anymore. The owners name was Rich Krongeld (sp?). I have more info at the hangar, but it is dated.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 05-13-2017, 05:01 PM
Any info from hangar would be great. Install manual?? I have the operating manual but no install info. I need to somehow change or (trick) signal for the new pmag. RPM value now with two pmags is reading double on the IK. Idle on ground @ 700 is reading @ 1400. Cruise power @ 2100 reading 4200.
Mike Robinson
RV-6a N731CK
52F
Old 05-14-2017, 06:12 AM
I have one one of these but do not have a config manual. It's a good monitor for everything except rpm. It reads 50 rpm low at 70F and 100 rpm low at 10F. EDIT: I have slick mags and hall effect sensor. I use an optical sensor on the dash. Not pretty but it's accurate. Only works in the daytime. http://www.proptach.com/
Old 05-14-2017, 08:59 AM
az_gila's Avatar
az_gila az_gila is offline
Find a local electronics guru. A divide by two digital circuit on the mag input pulses would probably be an easy, effective solution.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-15-2017, 09:05 AM
bsacks05's Avatar
My info from the hangar will probably not be too helpful since it is basic install and pinout data. Mine is an AIM-2 and not a 2000 like I thought earlier. However, I did find some contact info for when I had to have the processor reprogrammed.
Nu-Tron
911 Primrose Ave Unit P
Monrovia, CA 91016
Harry - 626-358-0228
This is the company that handled IK tech issues. Info is dated (over 10 years). I can send you a PDF of what I have just PM me an address.
Bruce Sacks
Warner Robins, GA
A&P
APRS KJ4EFS
