Addicted to the site?
Donate yearly (please).
Advertise in here!
Today's Posts | Insert Pics
Old 10-29-2009, 11:24 AM
256tylerw 256tylerw is offline
Default Tip: Brake Bleeding
We just blead the brakes and let me tell you what we think is the best way. We got a hand crank fuel pump for rc planes and put one end on the bleeder and the other in the fluid turned the crank and in 3 minutes both sides were done hope this helps someone.
Old 10-29-2009, 11:18 PM
E. D. Eliot E. D. Eliot is offline
Cool Awesome
idea - I assume that you 'pumped' from bottom up, right? Thanks for the tip.
Old 10-30-2009, 12:39 AM
Default brakes
Yes we pumped from the bottom and also if your system is full already and has air in it you can run the line in the resivoir instead of the can so you can just circulate it till the air is out.
Old 10-30-2009, 10:46 AM
Bill Dicus Bill Dicus is offline
Default Bleeding brakes
We've used an old "thumb pump" oil can with appropriate size plastic tube from Home Depot etc on the Pitts for years. Works great. You can leave the tube in place on the bleed nozzle while tightening the nozzle after filling, so spillage is minimal. The same rig works to top off the two individual brake fluid reservoirs (if you're down just a little on fluid from minor leakage) from the top. Setting up the -8 the same way. Not easy to include parking brake with this arrangement
Bill Dicus
Shorewood (Milwaukee) Wisconsin
Bldg RV-8 N9669D (reserved), finish kit
Flying Pitts S-2A, Piper Lance
Old 10-30-2009, 11:03 AM
boom3 boom3 is offline
Great idea! I even had a RC hand pump I could have used instead of buying a new $12 thumb pump. Oh well no biggie.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Finishing Kit
Broke since 2006.
Old 10-30-2009, 12:59 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
Send a message via Yahoo to RV7Factory
I'm curious... Anybody ever considered using Speed Bleeders on their RV? I had them on my last car and it made bleeding the brakes much easier.
Brad Oliver
Livermore, CA | RV-7 | Fuselage | N609BC
RV-7: RV7Factory.com | Blog: PilotBrad.com | iPhone app list: AviatorApps.com
Twenty years from now you'll be more disappointed by the things you didn't do than by the ones you did. ~Mark Twain
Old 10-30-2009, 02:08 PM
VAF garbage collector....
Considering we run the fluid "backwards" when doing aircraft, these bleeders wont work. The check valve is biased the wrong direction.
If you wanted to use them, you would have to work from the top (reservoir) down.
Rv-10, VAF 909
EAA 512
Working on window installation.
Old 10-30-2009, 04:52 PM
RV7Factory's Avatar
Yea but why? I know we push from the bottom -- I've done it myself -- but I can't remember why that is. It's friday, my brain is toast.
Brad Oliver
Old 11-06-2009, 08:40 AM
Default brakes
We also have the parking brake and it all blead out perfect.
Old 11-06-2009, 08:55 AM
Mel's Avatar
Mel Mel is online now
Super Moderator
Typically, we pump from the bottom-up because air goes up and this way we're pushing the air out instead pushing against it.
Mel Asberry..DAR
A&P/EAA Tech Counselor/Flight Advisor
n168tx(at)flytx.net
North Texas
RV-6 Flying since 1993
175hp O-320, 3-Blade Catto
