Larry DeCamp
I received doublers in a bag labeled RETRO 3-074. The bolt holes only align in pairs and only match the spars one position, ie, you can NOT interchange the top pair with the bottom on the spars. OK, I can live with that except these bolts don't match the pre-punched holes in the aluminum bulkhead panels supplied for the fuse. So I see my option is to "massage" the 3/8" holes in the aluminum bulkhead to accept the bolts ??
What did I miss in the instructions ?? The rear doublers in the control stick box will not go in. I can increase the clearance on the seat pan stiffeners to clear the 1/4" steel doubler, but they are too long to install. What am I missing ??
All suggestions appreciated...Larry
