Old 01-22-2016, 02:16 PM
todehnal todehnal is offline
It sure looks right to me!!
Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 01-22-2016, 02:36 PM
Originally Posted by DonFromTX View Post
From what I have read, it would appear that someone building yours drilled the hole in the canopy in the wrong place!
I have all the drawings, manuals, etc. from the original builder and so I will check dimensions when weather permits. Based on what I find I'll make a decision on how to proceed.
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 564
LSRM-A Certificate 2016 for RV-12 N633CM
Old 01-22-2016, 03:16 PM
Ex Bonanza Bucko Ex Bonanza Bucko is offline
For Piper J3:
What's that gizmo attached the canopy in the picture up posted?
EBB
Old 01-22-2016, 04:07 PM
BigJohn BigJohn is offline
Refer to KAI Page 34-11, Figure 2. The latch in the picture appears to be correctly assembled.
“Master Pilot” Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 01-22-2016, 04:08 PM
DHeal DHeal is offline
That "gizmo" appears to be the eyeball floodlight for the instrument panel that is part of Van's lighting kit.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 915+ hours (as of June 2020)!
VAF donation through June 2021.
Old 01-22-2016, 04:57 PM
aerofurb aerofurb is offline
Before anyone else asks J3 about the machine in the posted picture - he's already said, that isn't his 12!
Jerry Parr
England
Ex RV-12
Loving Rotax....
Old 01-22-2016, 07:13 PM
The forum is kind of dead tonight so I’ll digress a little…
Right, that’s not my 12 in the pic. I bought mine from the original builder and I knew it had some deficiencies. IAS reading high – sent back to Dynon for repair, stall warning inop – bad contact at wing root, small fuel leak in tank – tightened sender access panel screws, fuel pressure alarms – cleaned contacts on sender unit, dead battery in ELT remote switch, and both fuel tank and landing gear SB’s not complied with – to be completed this summer.
I bought the plane this past October with 50TT and now have 76 hours on the Hobbs. This is a wonderful airplane to fly. Control harmony, cruise speed, rate of climb, ease of engine management, ergonomics, unrestricted visibility, safety, ease of maintenance, easy ingress, economical to operate, just a real pleasure to own and operate. Did I mention it has real cabin heat?
This summer I will attend AirVenture for my fourth time. I’m signed up for the LSA Repairman Inspection Aircraft Course to be given the two days after the close of events. This will enable me to conduct my own annual condition inspections. I’m really looking forward to this interesting and rewarding experience.
I’m a 62 YO retired mechanical engineer. I got my pilot license in 1970 in an Aeronca Chief 11AC. I have owned a ’46 Cub for the past 23 years and traded it for the 12. I have about 1100 flying hours total. I thought I’d miss the Cub but the smile I get when flying the 12 erases any sentimental value I had for the old machine. I operated the Cub as Light Sport Pilot and will continue same with the 12.
In closing I’d like to thank everyone on the forum for their help and understanding each time I have asked questions in order to gain more insight into the workings of the RV-12. I’m sure there is much more to learn.
If you’re bored, here’s what else I do that’s aviation related http://www.rcgroups.com/forums/member.php?u=237058
A few pics of the old mount and the new bird…
EAA #499867
Old 01-22-2016, 11:27 PM
rv9builder rv9builder is offline
Nice planes, Jim!
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
Old 01-23-2016, 05:52 AM
Nice writeup Jim. Hope to meet up with you at OSH.
Old 01-25-2016, 06:12 PM
waterboy2110 waterboy2110 is offline
Here from TinyPic...
Thanks I learned something new today with TinyPic. Anyway, as you can see in the pic... the strike plate is within the handle loop. On my plane the extension tab only engages the strike plate. The extension tab is at the end of the handle loop. I will use drawings mentioned by Mitch757 for Default Canopy Latch - Check Vans Notification 14-05-22. I'll try to sort this out as soon as weather permits. Thanks for all the help. VAF is great...
The photo is correct and the rivets are correct. There is one left most rivet that is a counter sunk per the latest rev that calls out the canopy switch.
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P/IA Rotax iRMT 9 Series Maintenance
RV12 Flying.
