Skytrash
My right brake line failed again right where it comes out of the AN fitting attached to the caliper. It has only been a hundred hours or so since the last failure which occurred at around 700 hours.
I think the second failure was caused by the caliper vibration due to chattering brakes. I replaced the brake pads after the first failure but not the disc. I think the brake fluid (Mil Spec 83282) was absorbed into the disc and is causing the chattering.
I am installing a new disc and installing flexible lines next week during annual.
Has anyone had problems with discs absorbing fluid and chattering?
