What are you guys doing for shield to shield connections?
When you have two separate shielded wire groups that need to have their shields connected what is the best (most accepted) method?
I see a few options (and I am sure I missed a few)
1) cut the shield where the conductors exit the shield/coating, open a window in the tefzel maybe 1" further back and use solder sleeves to connect the two with a pigtail of 22 ga wire.
2)Extract the wires from the shield and use the shield length to connect to the other shield through some type of connection (solder sleeve?)
3) Other options?
Thanks in advance.
E
3) Other options?
Thanks in advance.
E
