Old 07-16-2017, 10:35 AM
stifler stifler is offline
Default 0-320 parts required
Hi guys
I am overhauling my 0-320 E2A to a 160hp and I need pretty much most parts. The way I figure it, it will be better to source the parts from the U.S. can anyone recommend a supplier who can supply all of these parts and will ship to the UK.
Steve
Old 07-16-2017, 11:37 AM
A1AVIATON47 A1AVIATON47 is offline
Default LYCOMING PARTS
BEST PRICES FOR LYCOMING PARTS, AIRPOWER INC. PH 888-682-6807
YOU WILL NEED H2AD PISTON AND HEAVEY PISTON PIN, THEY WILL KNOW IF YOU NEED ANYTHING ELSE, I THINK THERE IS A KIT . MIKE
Old 07-16-2017, 01:23 PM
Jesse's Avatar
Jesse Jesse is offline
+1 for AirPower.
352-427-0285
jesse@saintaviation.com
Old 07-16-2017, 01:34 PM
jrs14855 jrs14855 is offline
Default Parts
H2AD piston can be used but it results in higher compression than the stock 160 hp piston.
Dart Aircraft in Waco TX is an excellent source for parts. If you buy new cylinders you get everything except the piston pins, rocker shafts and rocker arms.
Old 07-16-2017, 01:51 PM
Hi thanks for the reply, what HP does the H2AD Pistons push out? I was thinking of using superior cylinder kits.
Old 07-16-2017, 02:04 PM
Default Pistons
IIRC Mahlon Russell estimates around 8 hp more than stock 160. I have 10-1 and it still is nowhere near 180 hp.
A stock 160 hp drops below 75% power at around 7000'. I seem to be able to pull 120 hp(75% of 160) as high as 9000'.
