carlrai
Last month, within a week of each other both faceplates on my radios simply let go and fell off. Garmin tech support had two options ? replace with new or re-adhere the old. Since the new parts are $44 each eek:!!!) I?m electing to simply reattach using the suggested 3M-99 adhesive, sprayed onto masked faceplates in a 1/16? band around the perimeter.
Figured before I started I?d post this aggravating little problem to see if anyone else had experienced this and the adhesive they used to secure the faceplates. CA?s (Super Glue) tend to fog plastic so I?m staying away from them unless one exists that is plastic compatible.
Appreciate any input.
