In what application, please?Anyone use high temp epoxy resin?
Exactly! On my cowling modifications, I used EZ-Poxy since the Safe-T-Poxy that came with my kit is no longer available. Where the exhaust came close, I applied Aluminized Heat Barrier. The stuff really works well and I haven't had any problem with it peeling off. I sealed the edges with red RTV.wouldn't a radiant heat barrier would do more good than higher temp epoxy?
Custom plenum and air intake. Maybe not really required but I ordered my last air intake in high temp epoxy from Sam James and it worked great. Previous one scorched from the exhaust proximity.
Think I'll just make plenum out of West Systems but was curious. I get the high curing temp as well which would be difficult in my application.
Good numbers for a room temperature cure epoxy. I have some exit parts running very close to a hot tailpipe without issue.
https://www.aircraftspruce.com/catalog/cmpages/htr212resin.php
West 105 has very low temperature ratings.
Wow! These are remarkable numbers for a room-temp cure epoxy. Prior to this, I considered MGS the gold standard, and Jeffco a close second, at half the price. I am testing a high T-g hardener from Jeffco now. But this HTR stuff looks amazing.
