I have about 80 hours now, and I've had 5-6 problems with the engine temp pick-ups. It's just a simple blade connector squeeze-fitted to a knob for both CHT indicators and the engine oil temp. Each time I've corrected the problem with a tighter squeeze, but only temporarily. Today I listened to the pesky aural "engine speed" warning and a flashing red tachometer on a return-to-base cross country because of the oil temp pick-up being not (quite) tight enough again.
Is there a compound I can apply to the sensor to remedy this problem? Anyone else experience this issue? Got an alternative solution?
Thanks.
Jim
N448JR
Thanks.
Jim
N448JR
