Everything is in the green on my Skyview Engine Monitoring screen. That is until I depress the "transmit" button on my control stick. Only while the button is depressed, both EGTs go instantly high into the yellow arc, and the battery charge indicator goes low into the yellow. As soon as I release the transmit switch, everything instantly returns to normal.
Clearly, at least in the case of the EGT, its an indication error. Temperatures can't possibly rise & fall instantly. So I figure this is just a glitch. Happens with the button on both control sticks.
Anyone seen this, or have a suggestion?
Jim
Jim
