For those of you that have removed the engine gear driving the magneto, what did you use to plug the hole where the gear shaft was mounted. On my io360 a1a the shaft has a oil hole in it that will continue to spew oil with the gear removed.
I?m going dual SDS electronic ignition. Wondering if there is a actual lycoming part before I just make one out of aluminum.
Keeping the gear with the fuel pump cam, removing the RH one.
Thanks.
Thanks.
