Hi,
I am having difficulty with my CanBus connections so I have only connected 2 LRU's with cable - Garmin GAD 27 and Garmin GEA24. Cable is between the 2 LRU's and cable out of each with no onward connections.
Note: Both LRU's are connected to their respective hardware (sensors, lights, flaps, trims etc)
Here is the query:
With both connectors out of the LRU's (not plugged in) all OK ie continuity independently along the HI and along the LO and along the shield. No cross continuity.
However, if I plug the related connector into either of the LRU's I get a resistance reading between the HI and the LO of 49 kilo ohms. (49,000 ohms).
Does this reading of such a high resistance mean NO continuity between HI and LO? and therefore the wiring is OK???
John (CanBus Confused)
Here is the query:
