Not sure which trim is used on the -14, but on my -8 I tested the Ray Allen trim motor using a 9 volt battery. Runs slower than normal, but good for testing. Good luck with your build!
It says ES-MSTS-T3-12A TRIM SERVO on
the drawings, I think it is Ray Allen 12A servo. So if
I will connect the right voltage to the right colored wires,
it will give me some motion, right?
Car battery works, but nowhere near as convenient as a 9 volt (as someone mentioned above). Yup - runs slower, but it lets you know that it is working.
