Old 10-18-2018, 08:26 AM
kbalch's Avatar
kbalch kbalch is offline
Originally Posted by Kyle Boatright View Post
Just checking - how much torque were you applying? These fittings should be tightened, not bottomed out.
I was thinking this, too. I've never seen a properly installed fitting snapped like that.
Remember that NPT threads should always get some lubricant. I've used FuelLube (now called EZ Turn) for years with great success.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494)
Std. kit begun 5/18 - Stick grip wiring, wheel pants, gear leg fairings, and misc. other pre-airport finish-up tasks
Old 10-18-2018, 08:48 AM
Walt's Avatar
Walt Walt is offline
To avoid galling use a steel fitting, alum-alum is bad juju.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-18-2018, 11:46 PM
didja didja is offline
Where does one get steel fittings for the fuel strainer? If there is a better way, I wanna do it! This aluminum fitting stuff is for the birds!!!
Scott Emerson
RV-14a Kit# 140432
Working on: Wings
Construction log: https://www.youtube.com/channel/UCaZ...Uv2rlQsHtdRmmg
Donation Paid (military)
Old 10-18-2018, 11:51 PM
So, after much consternation and hand wringing..... I was able to shop the local harbor freight aviation department and find the correct easy out and 3/8 NPT tap...… I finally got the threads fixed and even managed to run the square plug in through the fitting and it worked like a champ.
Now..... I have to wait for the replacement strainer so I can close everything up and then do the pressure test...….
Here is the threads after they have been tapped.....
Then I decided to test it with the square plug, which is the same size as the strainer...….
Square plug is installed with fuel proof sealant..... now just have to wait for the strainer and run it in!
What..... me worry?....
Again, thank you for all of your help! Always something new to learn in this project!
Scott Emerson
RV-14a Kit# 140432
Working on: Wings
Old 10-19-2018, 08:58 AM
Walt's Avatar
Didn't realize this fitting was "special" from Van's, looks like Van's just took an AN fitting and made it to accept a finger screen, shouldn't be hard to duplicate using a steel fitting. Worth the effort, maybe.
Old 10-19-2018, 09:20 AM
lr172 lr172 is offline
Often metal remnants from the male thread break off and lodge in the female threads. It is best to pick these out, if they exist, before you run the tap through to improve your chances.
Good luck.
N64LR
RV-10 in progress
