Old 07-03-2017, 08:04 PM
RV3bpilot's Avatar
RV3bpilot RV3bpilot is offline
I have used both Mobil one synthetic and Now Amsoil synthetic with no adverse affects and I use 100LL all the time, no auto fuel.
No sludge build up. Oil stays clean for a long time after I change it. I change oil every 50 hours.
I use 10w-30 synthetic.
There is no way I would use anything other than synthetic with a turbo charged engine because synthetic oils can handle much higher temperatures.
Robin Mckee
New Ulm, MN 56073
RV3b N219BB
318 hours and counting
Old 07-05-2017, 04:23 PM
TXFlyGuy TXFlyGuy is offline
Thanks. That is good to know. Real world experience trumps theory every time.
Old 07-09-2017, 08:02 AM
dlomheim dlomheim is offline
Robin: Aren't you running your RV-3B with a GM/Opel "ECO" Engine?
thx.
Doug Lomheim
RV-9A, Mazda 13B / FWF
Old 07-10-2017, 09:00 PM
RV3bpilot's Avatar
It's a Corvair engine modified to run in the aircraft. A very smooth running 6 cylinder engine.
With a turbo I have about 125 hp.
Robin Mckee
New Ulm, MN 56073
RV3b N219BB
Old 08-07-2017, 06:37 AM
We are planning to use Shell Rotella T, an ashless dispersant oil, just like Aeroshell. It is a full synthetic.
Old 08-07-2017, 08:43 AM
RV6_flyer's Avatar
Here is an article written in 1995 about the results of Mobil 1 Aviation Oil.
There are more stories but this one was the first one found with my search engine.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-07-2017, 09:49 AM
Here is what can be learned from this...do not use Mobil One in an aircraft engine, Lycoming, Continental, etc.
They are built with extremely loose tolerances, which results in far more "blow by" than you will ever have in a modern automobile engine.
Old 08-07-2017, 10:30 AM
rv7charlie rv7charlie is online now
While what you say about LYC/CON is true, that's not at all what I learned from this. My memory of the early problems with synthetic oil was that they couldn't/didn't hold the lead byproducts in suspension, so they accumulated in the engines as sludge.
Synthetic oil in a LYC/CON would be fine, as long as you're running lead free gas. (Temps shouldn't be an issue; synthetics have much higher heat tolerance than organic oils.)
Old 08-07-2017, 11:04 AM
That is why we have chosen an "ashless dispersant" oil, Rotella T, by Shell.
Old 08-07-2017, 01:40 PM
jim etcheverry jim etcheverry is offline
Unhappy Shell Rotella is NOT an ashless disperant
Shell's entire line of Rotella is a "low ash" oil. Not an ashless dispersant.
