I'm close to the stage on my RV-7 build where I will need to finalize the position of the pitot tube, and I'm looking for a bit of advice. I have a SafeAir mount, and a heated Garmin GAP26 pitot, although I think the question probably applies more broadly.
My main concerns are making sure that I get an accurate reading (which as far as I can tell mainly means making sure the pitot is in undisturbed air and parallel to the flow), avoiding any fouling of the aileron pushrods or bellcrank by the internal tubes or wiring, and perhaps most tricky, preventing potential damage to the expensive pitot (or even worse the wing) due to entanglement with a tie-down rope or chain.
I note that the Garmin instructions simply say "mid-span", and that the Safeair instructions suggest mounting one bay outboard of the bellcrank bay. The Vans plans have the pitot slightly inboard of the tie-down ring location. This makes sense to me because given the narrow wingspan of the RV aircraft it's much more likely that the rope or chain will extend outboard from the tie-down than inboard. To make the thread most useful, perhaps I can ask others to comment on the three possibilities as follows:
1) Has anyone tried mounting the pitot inboard of the aileron bellcrank? Would this cause inaccuracy due to propeller slipstream? Does it solve the tie-down-fouling issue?
2) Has anyone tried mounting their pitot further outboard than the bay next to the bellcrank? This would make riveting and maintenance more difficult, but might solve all the issues. Could inaccuracy be introduced by being too close to the wingtip where air starts to travel spanwise and leak around the tip?
3) Should I just stop worrying and mount it where the SafeAir instructions say? (In the next bay outboard of the bellcrank, but as close as possible.) Is anyone who has experience with this location able to reassure me about tie-down damage?
Thanks in advance to anyone who responds. I have seen some other threads on the subject but am not aware of a definite conclusion being reached (perhaps that never happens....)
