Navworx , back in business?
THANKS DAVID
This was certainly worth more than a penny and answers a few of the outstanding question while giving us something positive to hang our hats on.
Hopefully soon, the individual and Global AMOCs will be published. For those of us getting individual AMOCs - we'll be good to go post 2020 as is...although some of the features touted in the new software release will be nice to have as soon as possible...Display Port 2 and Anonymous Mode jump right out for me...although the SL-70 fix may be needed for more of the certified guys as Garmin sold a bunch of SL-70/GX-60/SL-30/MX-20/SL-15 combo platters.
Again thanks!
Thanks David for the Update, and also Dan for the question asked. Although sounds like the 1090 receive for the 600EXP maybe " next round" Thats OK, I would be happy to just see the AD go away for this round. Maybe the FAA can make the approval and allow Navworx the time to produce some parts for us within the 6 mths.
Back to the beginning - Navworx , back in business?
I believe they are.
Spoke with Bill Mofffet regarding my order of last August. He said it would be filled, hopefully by end of August with a black certified box without STC label. The transmon has been incorporated in the box so it, with the GPS they send, should put me in business re ADS-B via UAT.
It was amicable conversation, parted with hand shake. I asked if war with FAA was over and he responded it is settled. :)
The unit looks good in the photo. Just curious does the GPS ant plug into the piggyback unit or remain connected to the original connector on the EXP?
It all stays the same from my understanding. Your existing 9 pin harness now connects to the piggyback box, which jumps to the original 9 pin connector.
The one question that has not been answered to my knowledge...:
Will software version 5 work WITHOUT the hardware changes?
It is addressed in the service bulletin. V5 will auto detect the gps source and set the SIL value appropriately.
The GPS antenna plugs into the piggyback unit according to the long conversation I had with Bill Moffet.
The add-on GPS module (I was calling it "the doghouse" since that is where NavWorx found itself with the FAA) attaches to the ADS600-EXP by way of three existing screws. You take out three of the screws that are already there holding the sheet metal cover on, then locate the doghouse and reinstall the three screws. You move the GPS antenna connection from the main unit to the doghouse (blind side of the image in the flier). You unplug the aircraft harness from P1 and plug it into the doghouse connector. You plug the doghouse ribbon connector into the P1 plug on the main unit. Then you load software version 7.0.
What you don't want to do is load software 7.0 without having installed the GPS doghouse, because the software is designed for the new hardware.
Software 5.0 is not for the EXP unit. That's for the certified unit.
Thank you David for clearing up the issue on where the gps antenna attaches.
And, I'm happy to hear the doghouse attaches using the existing screws & holes on the main housing.
Saw this posted on the Dallas Avionics website regarding ordering & shipping of the new 600EXP gps module.
https://www.dallasavionics.com/cgi-bin/navworx.cgi?faction=ads600exp
Here's the text.
Experimental Aircraft ADS-600EXP System:
In order for Experimental Aircraft with our ADS-600EXP Systems to comply with AD all Systems must update software to new revision (when released anticipate 8/15/17) and must install EXP GPS Module (we anticipate to begin to take orders 8/7/17 and begin shipping in 8/15/17).
GPS Module Price is $299.00
GPS module will install in aircraft and will not require any additional wiring changes. Module will be "Daisy Chained in Series" with existing system utilizing existing EXP system wiring and connectors.
All orders will be through Dallas Avionics, Inc. Orders will be accepted on 8/7/17.
Note: Experimental owners with ADS-600B System must comply with ADS-600B criteria.
Dan, thanks for the link.
"Dog house" ordered this morning. I will be glad to get and install it to (hopefully) close another chapter on ADS-B installation. I'm not into drama...I just want it to work.
Report after install please!
Jaws,
Let us know how the reinstall and functionality checkout go!
The rest of us are interested in what functionality was added / promised but still missing.
Thanks!
Ordered mine as well. Im also adding wire to accomodate a recently new to me GTX 327. Does anyone know where to find the navworx "console" to be able to reconfigure the 600exp when i get this done.? I didnt find it on the navworx site. Im removing the transmonSPE. Not sure why, it seem to work fine.
You should be able to use the iOS app to configure it via WiFi. (Is there an Android app? Never looked .. ) My 600EXP is connected to my 327, no problems works great.
Not to be a downer, but, when you all ordered the gps unit, will there be a hard copy document included from the FAA that states the unit will now really, really be in 2020 compliance?
Or is there a promise ?
Dan - -
Fully appreciate your concerns. I waited a long time too. Dallas Avionics is listed as having 264 employees. Can't imagine they need a major size problem like that. Not sure how the FAA will know, but I plan to take pics and have paperwork ready if asked.
All just verbal across the counter at OSH. They said they were awaiting FAA approval before the "dog house" is mfg. Said it would have a SIL 3 when the 7.0 software was loaded. That should be good to go for 2020 in an experimental. " He said" . Fool me once , fool me twice, I've sill got one more to go!!!
The console is a chunk of software from NavWorx - you connect some wires to a DB9 RS-232 connector to a computer with a serial port and configure it remotely...wiring diagram in the manual...might be different for the EXP boxes!
Need more help - let me know...I have this wired in mine...
The 600EXP uses a downloaded block of software that was found on the Navworx site the first time I did this. After downloading it specifically for the 600EXP it connects up with that unit via the Wi Fi and allows the set up to be done. I was thinking it was called " UAT Console EXP installer" I could be wrong. I'm currently looking on my older laptop for that software . Someone said it was available on an apple app not sure about android. I did however find a UAT config app on android but chose not to pay $10 for it. Still looking.
EXP Firmware updates
There are (potentially) two ways to update an EXP unit: Windows PC or Apple iOS app. Bill (Moffitt) has not yet made the new firmware available or supplied me with a revision history document. I do not know when this will happen.
If you have a PC laptop and can run it at your plane you should be able to download (free) the Console app to do the firmware update from navworx.com. If you prefer using an iPhone or iPad, you can download the ADS600EXP Config App from the App Store for $0.99. Bill had me charge a buck for it to discourage accidental downloads.
NOTE for iOS/Apple users:
When Apple released iOS 10 they broke support for WiFi connection with certain internet IP subnets. There was nothing wrong, technically, with this subnet but Apple seems to think otherwise and interprets it as "no connection". This is probably greek to some readers... so keep reading.
Due to the early (pre 5.7.x) firmware using the WiFi subnet that Apple does not like, the app will not update the EXP unit from < 5.7 firmware unless you are using an iPhone or iPad that has iOS 9 on it. Your choices are to use the PC console one time to get to at least 5.7, or to borrow an older iPhone (4S or 5) or older iPad that is still running ios 9.
I have a few iOS 9 iPhones lying around and plan to make these available when the navworx update firmware comes out. I'm willing to mail these to conveniently located EAA chapters or friendly VAF'ers so planes can make a short hop to centrally located airports and update. A mail-forward of the devices may work too. I'm trying to leave this up to Dallas Avionics to stage manage when the time comes but I suspect I'll be helping to organize it.
The app will usually let you listen to the EXP unit and see the current firmware version number. This will help you determine if you need to go the PC route or find an orphan Apple device on which to run the app.
Hope this helps clarify the upgrade mechanism for the -EXP units.
Navworx GPS Module
Anticipated ship date for the GPS module was 8/15
Has anyone received the unit from Dallas Avionics?
Don B
Don,
The expected software release date was also published as 8/17.
No software yet either.
My understanding is that Bill and the NavWorx team had to get AMOC's for their hardware and software changes - and they're not willing to ship until they have full approval from the FAA to prevent a repeat.
There are a number of 'other' AMOCs and AMOC amendments in the pipeline as well!
Someone else can verify this.....
Just received a FAA Safety email.
FAA Safety Team | Safer Skies Through Education
It’s not too late to reserve your ADS-B Rebate! NavWorx avionics now eligible!
Notice Number: NOTC7328
Attention pilots and aircraft owners: The ADS-B Rebate Program will now allow aircraft owners with NavWorx ADS600-B avionics, part numbers 200-0012/0013, to apply for a rebate.
To be eligible, rebate applicants who purchased and installed these NavWorx units after September 19, 2016 must comply with section (e)(1)(iv) of the recent Airworthiness Directive (AD 2017-11-11), or use an FAA-approved Alternative Method of Compliance.
The FAA is offering a $500 rebate for new ADS-B installations in fixed-wing, single-engine piston aircraft. The last day to make a rebate reservation is September 18, 2017, if reservations are still available. Once the reservation is established, you will still have up to 150 days to complete the remaining steps in the process.
Are you eligible for a rebate? Please visit faa.gov/go/rebate/ for details.
Questions? For questions about the ADS-B rebate program, please contact [email protected].
EXP Software
I have been watching the NAVWORX site for the promised EXP Version 6.0.0 and 7.0.0 software and haven't seen it. Would like to purchase the EXP GPS fix but wanted to see that the software promised 8/15 is available first.
Next question, has the FAA approved the use of the new GPS and version 7.0.0 software as a remedy for the AD?
Ron
Ron
In working with the FAA to get the AMOCs that were published last week, I was told that they really were impressed with Bill's submission and technology. They couldn't say anything more due to NDA.
I know that ours were held up a week or so to ensure that they would be eligible for the FAA rebates. I would suspect that Bill is having to deal with similar opportunities.
While I don't really know anything more than what I've shared, I would suspect that everything will be available shortly. The FAA doesn't publish dates or set any expectations on when they'll complete tasks. Mentioning a date may not have been the best decision for Navworx. I would give them a few more weeks to allow the FAA to do their stuff.
While I have an AMOC to make me legal again, I am still going to upgrade. I just don't want to be in the front of the queue.
Hi all,
Can any of you that has one of these confirm or deny whether it works with ForeFlight at all? I got an unconvincing "well, it's an app so it should work" answer from someone at Navworx, however I have been unable to get a response from anyone else there who knows for sure. I'm trying to make a decision on what's next, e.g. GTX-327 now w/ Navworx in a month or two when they ship, or just bite the bullet and go with a more expensive all-in-one option that I know will work. As my current transponder has failed and I need Mode C to fly here, I need to decide quickly.
Thanks!
keep the 327 and go with the new Garmin GDL82. Cheaper and problem solved. I would never in a million years recommend Navworx. Not that it doesn't work, but the whole way everything went down the FAA was sketchy, at best.
As I read his post his current transponder has failed.
If he doesn't mind used, 327's are going for $400., a great deal.
If only new equipment, some mode S-ES transponders are now in the $2K price range, e.g., Trig TT22.
Like you, I wouldn't touch navworx with a ten foot pole. Besides, there are now less expensive options.
ADSB and ForeFlight
Hi all,
Thanks!
We installed the Appareo Stratus ESGi Transponder with 2i; which gives you a 310 watt WAAS Mode ES transponder; with ADSB IN/OUT on 1090 & 870 Plus weather into Foreflight on our IPad Mini. Easy installation & never looked back.
So, different feedback than I was anticipating, but useful. Bob is correct, my current transponder ate it a few weeks back, so I am exploring options. An avionics shop I am working with suggested the 327+Naxworx combo, but I have a couple criteria including ForeFlight, so I don't know if that'd even work. They also suggested using a portable box alongside the Naxworx for 'In', but I want a fixed In receiver and less clutter. I use a stratux already. Plus, having to augment a device that already provides something with another device to do the same thing is just ... silly.
The one and only real drawback with the Appareo is lack of an output which can feed data to other avionics. It works with the iPad fantastically, however, and meets all other criteria.
With Garmin, it appears the only way to get single-box In/Out with wifi and future direct avionics connectivity is a GDL88 if I paired a 327, and at that point I may as well just stick a 345 in there, or go really nice and get a Lynx.
I was liking the Navworx concept - Out/In, wifi, ARINC+RS-232, WAAS, all in a box for about $2100 plus a cheap GTX-327 to drive it. But based on a lot of feedback in places like VAF, plus my own inability to even get a simple feature question answered, I am tending to agree other options will likely be better (even if more expensive up front). Garmin and L-3 aren't cheap, but they are always available on the phone.
Thanks for the input!
It?s not too late to reserve your ADS-B Rebate! NavWorx avionics now eligible!
Ralph, Phil, and I just received updated General Appliance AMOCs that cover just about every certified Garmin GPS to be used as a position source. They were posted to the AOPA site yesterday. If you used one of the original AMOCs, they're still good. The new ones just added more 4xx, 5xx, 6xx, and 7xx models, as well as fixing a FAA omission to include the 200-0012 for the Garmin 480.
While I would still recommend getting the Navworx upgrades. The AMOCs are a good stop gap to address the AD in the short term and to get a rebate for those that may be eligible.
bob
Hi all,
Thanks!
For many of us, we can't confirm the Foreflight support until 5.0 is released for the ADS600-B. There is a bug in 4.1.0 in which display port 2 doesn't function properly when display port 1 is serial attached to an EFIS. The symptom is that the iPad sees the SSID, recognizes the Navworx unit, but no traffic is transmitted. According to Bill, this is fixed in 5.0. The same symptom also is present with WingX.
You don't mention what else is in your panel. That would must likely cause me to sway one way or another on the recommendation. I personally like the Trig OEM transponders that Dynon and AFS are selling. Of course, you can get them from Trig too. With most of the non-Garmin EFIS, it would allow remote control and mounting and complying with the ADSB mandate. They tend to run about $2k.
I would agree if purchasing new. For those of us that already have sunk cost in a Navworx unit, the decision point is a little different for each of us.
In my case it's stick with the AMOC and use my 327 and the 650 as a position source, but risk future software updates may not support the original platform (costs $0.00), upgrade to the new boards and GPS ($600), or install a new transponder (Trig) and an ADSB receiver (Dynon/AFS) ($3,000).
What option I prefer and what option I can afford are different. Just like most things in life. :D
The Appareo Stratus ESG has GPS data out. Or do you mean it does not have traffic and weather? I like the fact that the Appareo is just one box, not dependent on other brand equipment. If two different brands are connected together and there is problem, each manufacturer will blame the other, leaving you caught in the middle. I would rather just have one box to fail, not two.
The above pretty much describes my situation. Although equipment is different, $$$ decisions are the same. With an unlimited budget I'd do a lot differently but as an "early adopter" of Navworx on limited resources my path is set.
BTW, I have had nothing but the best service responses from Bill at Navworx. Whatever I've asked for Bill was able to provide. Hope the same level of service continues under the new arrangement. As always, YMMV.
At the moment basically nothing of note. I intend to put in a 430W and Skyview HDX early next year, but due to my proximity to the DEN Class B, I must replace the dead transponder now to keep flying. However the future integrations also require a bit of forethought.
With that avionics combo I don't see any world where I don't end up with dual wifi networks running at minimum. The Skyview would provide one for nearly everything including VFR plans to the autopilot, but I'd want a FlightStream for loading IFR plans from ForeFlight into the 430, as manual entry is tedious on those. Given that, maybe I care less about the onboard ADS-B wifi capability right now and just run the Stratux for a while longer, and put that feature lower on the list.
So if you didn't place wifi as high on the list, but want fixed-transceiver In/Out with data (ARINC/RS-232) to other displays at minimum, which way do you go? This is where the Naxworx is appealing at least on paper, but obviously they have left a sour taste with many of you thus far.
FIS-B/TIS-B data out to another "box". If they were to include industry standard protocols, anything else should consume the data just fine. When I put the Skyview in, I want to see those things on the display.
If you are seriously looking at the Skyview HDX, then I would clearly recommend getting the Dynon branded Trig ES transponder and their ADSB receiver. That is assuming you want to scrape your Navworx unit It may have some resell value, but it's too early to tell at the moment.
Since you don't have the 430W yet, I would recommend talking a hard look at the Avidyne GPS. I'm not up to speed on the HDX, but I'm assuming many of the AFS features will cross pollenate across the Dynon line.
Foreflight works seamlessly with an AFS 5X00 EFIS and the Avidyne product line. You can transfer flight plans to/from Foreflight, as well as the EFIS airdata to Foreflight as well. BTW, AFS also can function as a Wi-Fi client to a Stratux unit too.
+1, except Ralph has indicated he's not yet ready to pull the trigger on the Skyview. And I think the Dynon/Trig transponder is remote-mounted, meaning he needs the Skyview to use it! Also, I think the Avidyne is a fine GPS, but notably more expensive than a used 430W. My recommendation is to immediately buy a used 327 for around $400 (plus certification cost). If you go a different route in 6 months, you can probably re-sell it for about what you paid for it.
I keep orbiting around that idea too. I eat a little money on it, but resale should be about what I pay now. It just goes away in the spring when I do the Skyview, and the plane is legal in the meantime. I am also waiting for an email from Dynon to tell me what 'In' transceivers would work now and in the future in case I just decide to go all the way now, but I was hoping for the Skyview's integrated remote boxes to reduce panel clutter when all said and done. I have since learned that they won't talk to a 345 or Lynx, so those are right out. :/
