jim miller
My RV3 (Late eighties kit) has several rocker switches on the lower edge
of instrument panel. Are these switches still available from Van's and in
use today on newer RV's? They have spade terminals with crimped connectors. Any recommendations for a good low priced crimping tool for
the insulated connectors vans sells? The plane also has a master solenoid
controlled by the master switch. What is the advantage over just using a
Potter and Brumfield switchable (31 series) breaker as both the master switch and main breaker?
Jim Miller
Jim Miller
