If you use a soldering iron round the tip on a grinder or scotchbrite wheel ....
If you use the scotchbrite wheel, you will have to toss the wheel in the trash as the steel particles that it took off the tip will be pushed into any aluminum that touches the wheel after that and will cause corrosion later on.
The grinder is better.
