Can you please offer your thoughts on the following two concerns.
First
Just below the front of the right rear window, I trimmed too much of the flange. The edge distance from the center of the rivet holes to the edge of the cabin top fiberglass is .306. Is this enough edge distance for fiberglass for the CS4-4 rivet.
Second
On both sides, just above the baggage door between the cabin top and the mid side skin flange there is a gap of 7/32. With some pushing from the inside, on the cabin top this gap can be shortened, but too much force would be required to completely close this gap. Can I build up the outside of the cabin top with a couple layers of glass to help fill this gap? The CS4-4 rivet would then likely be to short, so my plan would be to use a longer Cherry Max rivet. Does this seem reasonable and okay?
Extremely grateful for your thoughts,
Ron
First
Second
Ron
