Skyview Battery and EMS locations
I'm working on installing a Skyview in my 7, and was hoping others had recommendations on where to install the EMS and the batteries.
Thanks in advance!
tip up or slider?
the choices will likely differ between tip up and slider... i mounted my ems module to f-745-r forward of the map box; this is only an option on the tip up though.
for the backup battery i placed it on the subpanel right behind the skyview pfd. you can see it through the hole for the 696...
This is where I placed mine in a 7A slider.
Battery, pilot side.
And this is from the pilot side firewall , looking Aft. EMS
And your next question is here.
and here.
hope that helped. :)
