I am reading my SD-20 alternator installation manual and they recommend using a thin coat of Permatex or Hylomar HPF on the gaskets.
Has anyone used these products on an aircraft engine?
The material advertises that they are impervious to oil and solvents and this sounds good for sealing oil leaks through gaskets however if this stuff gets loose in the engine that might not be so good.
I was considering using it on the oil pan and accessory housing gaskets as well.
Any feedback?!?!?! THANKS!!!
