I am having difficulty fitting the supplied air filter, part 33-2060, to Part 2 baffle. I am building an RV8 and have fitted an Superior XP IO360 with a forward facing induction. After fitting the cowl and cutting the baffles to fit the cowl the baffle is now too short to fit the filter. I have also tried a test fit of the snorkel and found that it is between 1" to 2" too wide it will have to be modified. Can a different size air filter be used? Maybe a conical or oval filter or can the supplied filter be built further down the into the snorkel.
Any suggestion would be helpful.
