rv9aviator
I ordered the Vans wing walk material with the lettering cutouts (RV-9A ) and am wondering how to install it. The material is a sticky back with the letters still on the material but you can faintly see where it is die cut to be able to remove the letters so the paint below the wing walk will spellout RV-9A. It doesn't look like it is cut all the way through but maybe it is and you really can't see the letters looking from the top side. I guess I could peel the backing paper off enough to see the letters from the back side and try to remove them before I place the material down on the wing or I could lay the whole sheet down and try to unstick the letters and remove them. Either way doesn't look very easy. Looking for advice from someone who's already been there done that. Thanks!
