Old 07-30-2017, 10:00 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Some more info from Dave flying back home from Osh:
"This was after leaving Great Falls Montana on the way home. Those are obviously incorrect winds and xw. Then look at 31.4 mpg at this low altitude at about 20” MAP at 2200 rpm, while truing 197mph. I love this system, you can full power or lean with no problems and it starts like a car, even on hot starts."
Dave says he's overcooling in cruise running LOP and will look at reducing the inlet ring size at some point.
The SDS programmer here shows the AFR at 16.7 which is well LOP.
Turbo Subaru EJ22, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW- 415.8 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 08-01-2017, 04:36 PM
rv6ejguy's Avatar
Default SDS Digital Fuel Flow Accuracy
Some more feedback from Dave today showing the accuracy of our optional FF software. We generate a pulse train from the ECU to feed the engine monitor so no Red Cubes are required.
"Just wanted to let you know that the speed we did in the race was while burning 14.5 gph, confirmed by the max FF indication I was getting when using the SDS fuel signal was within 0.1gph and confirmed by the fuel added at the pump at the pit stop, so at that flow, the FF was accurate to within .227 gals of all the 32 gals in my tanks. During those conditions my engine was producing about 194 real hp at 2830 rpm. Also during the race I burned the left tank out until I saw the fuel pressure fluctuate 2-3 lbs off of max pressure then changed the selector to the tanks without even a hesitation in the engine operation.
hp = 14.5 gph x 5.9 lbs/gal / 0.44 bsfc"
Old 08-01-2017, 04:54 PM
M McGraw's Avatar
M McGraw M McGraw is offline
Default FF calc
I have been collecting a lot of data on my install. I do plan to publish it in the future after about 100 hours of use. Currently - at 50 hours - I am consistently within 0.1 gallons at fill up on my IO-390 using the SDSEFI system.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 50+
Old 08-01-2017, 05:11 PM
rv6ejguy's Avatar
Thanks Marvin. Barry will be happy to know all his hard work paid off writing this software. It was dead on in lab testing but nothing like these real world results on running engines to fully confirm.
Old 08-01-2017, 07:01 PM
Toobuilder's Avatar
Im very happy to hear the computed fuel flow of the SDS ECU is consistently accurate. I never liked that fuel flow meter clap trap on the engine and especially after Dan dissected one which revealed the miniscule flow passages. Good riddance!
I have just flow tested my new fuel system for the Rocket and am happy to report that it flows 60 GPH with the single pump and 90 with the second running. During the retrofit I went to great lengths to eliminate 90 degree fittings on the suction side, including changing the in tank pickup to a straight fitting. An interesting side note is that I also intended to run two Faccet cube pumps as "pushers" right at the wing roots thinking that my planned use of auto gas would need help to prevent vapor lock. I decided to only install one cube pump for the test period so that I could easily determine if I needed to add the second, or remove the first. During the FF test I noted that the "cube side" sounded more labored than the "non cube side" despite the fact that there was no measurable difference in delivered flow rate. Based upon this, I would not be surprised to find that the added restriction of the cube pump has actually increased my susceptibility to vapor related issues. Testing will determine.
At any rate, the less hardware in the loop, the better! Thanks Ross!
Michael Robinson
______________
Harmon Rocket II -SDS EFI instalation in work
RV-8 - Flying
1940 Taylorcraft BL-65 -flying
PA-20-inspired "family truckster" -in work
Old 08-01-2017, 07:41 PM
rv6ejguy's Avatar
Very good numbers Brad. What timing are you running? Compression ratio? Airframe? Prop?
