Old 06-18-2017, 09:06 AM
Plummit's Avatar
Plummit Plummit is offline
Default NACA vent attachment
The fiberglass scoops in the rear of my -10 were mounted with an adhesive and one started coming loose. Since the plane is painted I'd rather try the adhesive approach as opposed to rivets. Is West 105 adequate or is there something better?
~Marc
N814RV
2017 Donation made X4
Old 06-18-2017, 09:26 AM
Tbone's Avatar
Tbone Tbone is offline
Default Glue
I glued mine on with E6000 adhesive. (Goop) works great and quick.
___________
Terry
RV7
XP IO360
Old 06-18-2017, 09:50 AM
rocketman1988 rocketman1988 is offline
Default second...
Second for the goop. I used pro seal initially and it seems to be holding fine...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Dues Paid 2016,...Thanks DR+
Old 06-18-2017, 10:10 AM
Auburntsts's Avatar
Auburntsts Auburntsts is online now
I used proseal on mine --- years later they are rock solid
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 06-18-2017, 11:51 AM
Tom023 Tom023 is offline
3M 4200 if you think you might need to remove them in the future, 5200 will make them permanent.
RV14A #83
Wings, empennage and fuselage completed
Finish kit in progress
IO-390 Thunderbolt ordered
Old 06-18-2017, 04:43 PM
Plummit's Avatar
Default Polyurethane
So the 3M stuff is a polyurethane. Is that the same for the goop/E6000? I see that the 3M stuff comes in a Fast Cure too.
BTW, this is FG to metal.
-Marc
N814RV
Old 06-18-2017, 06:13 PM
rleffler's Avatar
rleffler rleffler is offline
Proseal six years ago and they're still attached.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-18-2017, 06:24 PM
RV6_flyer's Avatar
ProSeal over 20-years ago. After more than 3,300 hours of flying they are still perfect.
Gary A. Sobek
KVVS RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 06-18-2017, 07:36 PM
sf3543 sf3543 is offline
JB Weld works great also. Scuff both mating surfaces for a better mechanical grip.
It held naca vents on my RV6 for 900 hrs until I sold it and nary a crack.
Steve Formhals
RV6, RV8 (2), RV12 & RV3 about 2/3 done.
A&P, Tech Counselor & Flight Advisor
Old 06-24-2017, 10:35 PM
Plummit's Avatar
I rolled the dice, went to West Marine and bought the 3M 5200 fast cure. In my opinion it doesn't live up to its name (fast cure) but it's some sticky stuff! Test flight today and it looks like a good choice. Thanks Tom!
-Marc
N814RV
